Clutch bite
Right was in in the automobile just ther n in each gear it drives but if i put my too down its as if the clutch is slipping and revs go up n vibrations happen. Since ive had the car iv noticed the bite is literally letting go of the clutch basicly its tht high. Cud it be the pedal is set TOO high? So its sort of running on the biteish if ya get me? Worried incase its the clutch going on me. Someone told me tht trying to pull away in 3rd or 4th is a way of checking. Pull away in 3rd judding along means its slippin and cud be going but if it stalls then my clutch is cool. Tht right? Cos it stalled both 3rd and 4th. Anyone help a young man out? Cheers ppl :)
Under thr bonnet... look to the right on the gearbox. There's the cable attached to the arm poking out. Slacken the nuts on that cable and it will loosen off
Yeh just behind/below battery. thumbscrew may be locked with the little nut in front of it. 10mm spanner banner :)
