Clutch Air Bleeding Location and Jack Point is bent?
Hello first of all this is my first car and I'm not really educated in cars. I have read a bit on what to do when buying my first car and the first thing i want to do is changing all the Fluids myself. I have found the Drain points for the Oil, Engine Coolant, Gearbox oil and for the brake fluid the drain/bleeding points. The only thing that i have tried to find for at least 20minutes is the Clutch Air Bleeding Location. The Picture from the Service Manual doesn't help at all.
Can someone describe me where I can find this thing what is near it etc..?
Also when Lifting up my Car all points were extremely stable except for the Front Side it did Bent a bit any tips on what to do now?(should I keep using it)
I have the CR Engine with A/C.
sry for my English and i hope someone can help me out.
Unless you have a particular problem with the clutch, I would leave well alone for now you sound willing but probable lack the specialist vacuum bleed system to do this efficiently, second invest in a good low profile trolley jack and use the chassis near to the outer side of the vehicle only as it sounds like someone has distorted the main frame in the past, try to stay clear of the sill jacking points. for now stick to the engine oil and gearbox oil change first.:unsure:
