CMF_BeeBoop
» CMF MemberShould the digital clock on the dash light up when the headlights are on? If yes, which bulb do i need to replace?
Jon WROTE:
"Yes, the clock backlight should be on when your headlights are on as well as accessories/ignition.
The globe that needs to be replaced is behind the cluster and is held in by a brown/orange globe holder. Easy to change as all you need to do is remove the dash surround, it can be a bit tight reaching in behind the cluster though.
