Hi
The engine light is on in my 2000 1.0 K11 and wonder if I can check the code without a OBDII instrument?
I actually have a cheap OBDII reader but it doesen't seem to respond at all when I plug in... fwn
The car seems to run fine, but I suspect the O2-sensor because it had a bit higher lambda readings at idle at it's last check up than usual (swedish MOT)... 1,03 allowed: (0,97-1,03)
