Hello everyone,
I own a 2002 Nissan March K12 with auto transmission. A few days back, after work, when I got to the car to return back home, the check engine light remained on even after the car had been started. While the light was on, the engine would not accelerate even if the accelerator pedal was depressed all the way. I turned the car off and turned it on again. It was back to normal, to lights on the dash were on.
Yesterday, on my way back home, I stopped at a shop to pick up some groceries. When I started the car after shopping, the check engine light remained on and the engine would not accelerate as it did a few days ago. I tried switching off and on again as I did earlier. Did it twice but the light remained on. I had to drive the car with the light on and no acceleration all the way home, somehow managed it as I was not far from home. Upon reaching I switched off the car and turned it on again. This time, the check engine remained on and the overdrive light started flashing. I turned off the overdrive and turned it on again. The overdrive light went off. I switched off the car and turned it on again. This time the check engine light also turned off. I tried turning off and on again a second time, this time, too, the car was normal and also revved / accelerated normally. This morning I started the car to go to work and it has been normal so far except a little jerking when idling at a traffic light with the gear lever in D, brake depressed. After that it has been normal so far. I do approx 10kms to work dropping my kids at school on the way and same on my way back.
Has anyone experienced this?? any help solving this shall be of great help......thanks.
