infinity Apr 27, 2015 #1 Hi i got a set of alloys but the wheel bolts arent long enough to use them. How do i go about changing them? Anyone know what size and where to get them? Thanks
1275 Apr 27, 2015 #2 The K11 has studs. Are you sure your issue isn't related to a too small centre bore on the wheels stopping them going on properly?
OP OP infinity Apr 27, 2015 #3 The center bore is much bigger so thats not the problem. Can the studs be changed?
frank Club Member Apr 27, 2015 #4 this k11 bolt is 40mm + the flange (14mm and a bit spline), and my old super s had these shouldered nuts fitted
OP OP infinity Apr 27, 2015 #7 Just searched now. For future refrence its 12x1.25 and spline diameter is 14.3.
tomwest Apr 27, 2015 #8 you can get them fairly cheap on demon tweeks. http://www.demon-tweeks.co.uk/performance/wheel-nuts-bolts/grayston-wheel-stud
