Changing the throttle body
L
LA_469
hi ,
I have read that a few of you guys have change to GA15 or GA 16 throttle bodies on your CG13. My question is does it give extra power . Why does people change to the GA15 and GA16?What are the advantages?
Also, if i intent to change to the GA 15 or 16, is there oher thing that i need to do apart from just swapping the TB.
Any help is much appreciated.
I've read that the GA15 is a direct replacement on the CG13DE but a GA16 will need a plate - i believe cisco's micra files have more information.
no adapter plate is needed unless you are fitting the sr20 throttle.
In my opinion and my personal experience i wouldn't recommend a different throttle body on any mild tune k11.
