After fitting an aftermarket exhaust muffler and back-box, the exhaust has a tendency to scrape on the road when going over speed-bumps with any sort of weight in the back of the car in excess of 40kg or so. I was looking at a Koni suspension kit which would lower the car by at least 30mm, but this will more than likely cause the exhaust to hang even lower.
I've raised the muffler all the way up to the bumper of the car so I can't possibly raise it any higher without cutting into the bodywork. Would it be a case of tuning the suspension so that the ride height did not drop when under load, or would I need to consider using bigger wheels to give the car more clearance (current 15" wheels)? Or would I have to do something else entirely? Suggestions anyone??
