Hi everyone.
I have a little bit of a problem with my wife's micra.
She owned the car for about 6months and from the very 1st day there was a few things that worried me.
When changing from N to D there is a noticable jerk and when driving and the gearbox is on 1st gear it always revs very high and then when it's changing to 2nd it is very harsh change, like a kick in the back. All other gear changes are smooth and hardly noticable. Just from N to D and 1 to 2 are very harsh and jerky.
I don't know when and if ever was the gearbox fluid changed so I decided to do it just in case. I used Millers Oils Millermatic ATF SPIII-WS. But that's not the problem.
The real problem is that everywhere I checked it said that gearbox oil capacity is approx 7.7l. When I drained the oil I got only 3l?!?! And then when I refilled I've put in 4l and it was full on the scale on the stick. I did run the engine idling for 5min, checked the oil level again and nothing has changed. I took it for a litlle ride and oil level OK after that. I did warm up the fluid befor draining too.
Now the jerk when changin from N to D is half less harsh but from 1 to 2 still the same.
Can someone tell me why did I only get so much oil from gearbox and what can be possible cause of it? Also what else can I do to fix the jerky gearbox without spending fortune?
Thank You and sorry for such a long post!
