CMF_gu_niang1200
» CMF Memberdoes anyone here knows if the CGA3de 1387cc has bigger pistons than the CG13DE 1275cc or it is the the stroke of the cyliner that makes the diff ..
with a Tomei 256 pon cams and the Tomei 0.7mm gaskets .. does it fit the CGA3DE?
Wil there be any problem with the knock sensor if we straight bolt the CGA3DE in the our micra/march whcich has CG10 or Cg13?
How abt teh ECU// ? are they all the same or we i have get the CGA3de original ECU..
There are two kinds of CGA3de.. one which has a 85PS output... and the other 100 PS output//
I came to realised there are differences in the Throttle body for the CGA3de and CG13 engine.. the CGA3de has two plugs near the TB.. CG13 has only one..
Any expert bros out there can help these QQs?
