CGA3 engine suits CG13 gearbox?
Hi guys,
I have a Micra 1.4 CGA3DE. Unfortunately the gearbox won't stay in fifth gear. Maybe a gearbox change is the only option.
I have no CGA3 gearbox, only a CG13DE gearbox.
Will this fit? What else do I have to change?
when my 1.3 box began to slip out of 5th gear after a hard trackday (I could even hold it in place when applying any torque), I dismantled it all and found it was caused by worn mashed up teeth on the selector ring
(worn teeth: bottom vs newer teeth: top)
so here's the worn teeth on one side of the ring that engages 5th gear
I found that the selector ring is made symmetrical so there's another set of fresh teeth on the other side that's never used.
you could flip the selector ring around for a fresh set of teeth which may stop it slipping out of 5th (assuming the engaging teeth on the input shaft are also in good condition).
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-119#post-706020
That's a cracking bit of advice there buddy...really interesting to me..thanks.:)
