Cga3 crank into cg10
Hi all searching around it looks like you can put a cga3 crank into a cg10 and I think Frank has done it looking at some posts
But I cant seem to find in what configuration ie
Cga crank but which rods, cga or cg10 rods and pistons
Pre coilpack cg10 by the way
I understand you can use cg13 crank and rods to simply stroke it to 1300 or using cg10 pistons to raise the cr
Cheers dudes
Cg10 pistons I assume? Looking at the pic at the top of the thread?
I'm just exploring options as cg13s seem like rocking horse poo up here so if a cga can be used then ill keep an eye open cheers man
