cg13de performance engine??
Hi everyone just on the look out for advice i have recently bought a cg13de engine and want to get some decent power out of it.... im hoping to get some fast road cams skim the head and rebuild the engine in general! i have a spare 1l engine sat around and heard they have a bigger compression ratio? wanted to know if this is true or there is some off the shelf high comp pistons? or some out of another engine that would do the job?
Also wanted a bit of help on the inlet side of things... is the 1.5 almera throttle body worth getting and will the 1.6 injectors be up for the task with the cams? and where abouts can i get a standard ecu remapped to spec?
