Cg13de into k10 injector problem
Hello, i bought a donor k11 prenats car, i have wired everything i need to make the car start with information from other threads. (3 wires from white plug to 12v ignition feed) but i wont get any injector signal, the car will start on brake cleaner, but it wont get any fuel obv. Without injector pulse.
searched everywhere and looked through wiring diagrams and everything
needed to add 12v feed to the camshaft position sensor to get spark, had no spark with only the 3 wires
fuel pump off diffrent switch
igniton off diffrent switch
everything realayed and fused
i have 12v into the injectors
