carnutterk11 Oct 1, 2018 #1 hi. dose a cg10 coil pack head fit the cg13 block? sorry posted in the wrong part befor. thank you
OP OP carnutterk11 Oct 1, 2018 #3 sweet. mines 1.0 but coil pack and want a bigger engine in it but cant find a 1.4. someone told me that i could use the 1.3 bottom end for more power
OP OP carnutterk11 Oct 1, 2018 #4 cos all the 1.4 engine i find are for the k12. is it hard to put a k12 engine in a k11
frank Club Member Oct 1, 2018 #5 a k11 1.4 would be a lot less hassle, the 1.3 does,nt have a crank sensor or cam sensor, and the k12 cr14 has a lot of differences
OP OP carnutterk11 Oct 1, 2018 #6 ok thank you. so best just to look for k11 1.4 then. how hard would it be to do cg13 and engine loom to get rid of the coil packs or is that a lot of work
frank Club Member Oct 1, 2018 #7 i think you would need to swap the whole engine and cabin looms, different type of ecu etc
OP OP carnutterk11 Oct 1, 2018 #8 ok thank you mate. ill just keep a eye for a k11 1.4 engine then. lol
D Descent Oct 4, 2018 #9 its calld a CGA3DE if that helps. Love it, alot of bottom end tourque! Sent from my SM-G930F using Micra Sports Club mobile app
