Hi all i know these questions proby been asked loads of times, ive done some seraching and its mixed anwsers in defferent threads, im new to the k11 and their engines, im quite capable of tuning & doing the work myself. I want to go the n/a route and im not after big power just a few more ponies
1. are the cg10 pistons a straight swap - as in no head/gasket change needed ?
2. is the 1.0 gearbox a straight swap - no need to change the fly & clutch ?
3. do i need to use the cg13 ecu instead of the cg10 ?
4. any engine parts i should replace other than usual seals & gaskets ?
5. any other mods/work i can do while the engine is apart ?
Thanks for any help!
