cg13 conv fueling any ideas?
jamieccc
currently doing a cg13 pre 96 engine conv on my k10. I will be putting a swirl pot in to the system aswell
Few questions i need a little help with.
Fueling:
any ideas on a pump to use? i was thinking bosch 044 external mounted
this is what i was looking at took it from another site. just dont understand the need for 2 pumps thats all.
any helpers? cheers
I'm running somthing simalar to that pic,
I've got a facet pump running low pressure fuel thru existing fuel lines (no need to upgrade to high pressure pipes) into swirl pot, then higher pressure pump to feed my fpr/carb setup, (or fuel rail)
I have seen another blog somewhere, and they managed to fit the k11 fuel pump into the k10 tank, not sure if figaro fuel pump fits either
