I have a 1995 K11 with CG10DE Engine and CVT Gear box and it needs a rebuild.
Having read through the forums, will the following parts from CG13DE make effectively make my 1.0 into a 1.3 without any issues?
- CG13DE Piston, Crank and Rods
- CG13DE Camshaft
Since the CVT gearbox favours the low/mid band, would it be best to run 1.0 pistons (Higher Comp 10.2:1) or 1.3 pistons. Not sure if there would be issues using the 1.0 gearbox.
I also have a throttle body lying around from a manual GA16, but I understand that an adaptor is needed and I would need a non nats ecu from the same car.
Any advice would be appreciated.
- CG13DE Camshaft
