Hi guys, first post so feel free to castrate me if i asking something that i could have found here but i have searched high and low and really cant find anything.
I have a micra with a 1.0 coilpack engine in it. I'm going to replace this engine as it inhaled a puddle during the winter!.....however, I'm a bit stuck on what will fit as opinions differ. I'm wanting to keep the 1.0 ecu gearbox/flywheel etc as this is being done on a very tight budget and the close ratio is appealing!
So basically i want to change the engine but retain the 1.0 ignition system, ECU and gearbox.
my sticking points are:
- Will any CG engine fit mechanically with a 1.0 coilpack gearbox/flywheel? id like to put a 1.3/4 engine in her
- Can i trigger the coilpack setup using some setup on a pre-coilpack engine?
