Cg10 coilpack compression test.
4- 130psi
3- 134psi
2- 128psi
1- 128psi
They all are within the 10% limit but it might be my compression test tool thats leaking as i saw it smoking but it dont loose pressure when you leave it.
Cheers in advance
The compression tester wont show a pressure drop due to them having check valves built in.
Assuming it's an unmodified 9.5:1 motor in good condition, you should be in the 170-180psi range.
I think my gauge isnt reading correctly as my other cars i have checked seem to run lovely and they all seem to have low compression. Confused :/
