Paul Smith
Site Supporter
Ok,
The cg10 has flat top pistons which are good and you can put 1.3 pistons in to lower compression - correct?
The cg13 has dished pistons and you can fit 1 litre pistons to raise compression - Correct?
So does the same logic work on the cga3 1 litre and 1.3 litre engines?
