welly Feb 18, 2014 #1 What injectors fit the cg rail? Got some ga16s but wondering if any others direct replacement
OP OP welly Feb 20, 2014 #3 Got my ga16 injectors, and throttle body which isnt a direct replacement Will be running 5 - 7psi will depend on air to fuel ratio
Enuo Glorified Electrician Feb 20, 2014 #4 198cc injectors are good for about 140hp iirc so could run about 10psi?
Enuo Glorified Electrician Feb 20, 2014 #5 Oh and you can remove and blank the Idle valve that fouls the fuel rail, its for when the AC pump kicks in on the N15
