cg block 56k still honing marks, ideal for project engine
£10 no postage but can deliver at expense
cg10 crank same as above but does the job, never been touched, so can be used for another project engine
£10 no postage but can indeed deliver or post at buyers expense
cg head, head it ok apart from it had a damaged valve in, seat looks fine just needs a new valve fitted and lapped in, or practise on port n polishing, with sensors
cg sump, no badly damaged some slight surface rust but will clean up, always handy just encase, could be used to fit oil return without disabling the engine etc
£10 can be delivered
cg non coil pack cam cover can be used to paint up and fit to the engine without disabling your own
cg inlet mani
£10 postage available
if not gone by the end of feb its all going scrap
cg inlet mani
