xXturtleXx91 Feb 21, 2012 #1 If the centre bore of a set of wheels is less than the micras 59 Can I use a set of spigot rings to increase it a couple of mm
MicrAde Feb 21, 2012 #2 How would that work then? Spigot rings would make the centre bore smaller, you need to open out the centre bore
MicrAde Feb 21, 2012 #4 correct either get them machined at an engineering shop or do it ghetto style, like I did, with a flap wheel in an electric drill
MicrAde Feb 21, 2012 #6 I had about 2mm to remove from each centre, iirc it took probably an hour per rim. Ran with those wheels on for a good few months with no issues whatsoever
Jay101 Black&Yellow Feb 22, 2012 #7 I took mine to engineering workshop, fitment was 57.1mm (VW) so needed 2mm shaved, cost me £10 a alloy.
