Cb engine differences
hi guys got a question for you smart people out there.
I put a post in the wanted section a few days ago looking for a Micra k11 cg13 engine for sale. Now I haven't managed to find one of these locally but I have found a cga3de engine for sale. Looking up this engine I have hit a bit of a blockade.
My car isnt a Micra its a mini with a Micra engine and it currently has a blown cg10 engine in it.
The engine is running on bike carbs, home brew manifold and megajolt ignition.
Now my question is regarding engine size and mounts
Is the cga3de engine unit mounted using the same engine mounts as the cg10 one?
Many thanks
Lawrence
So has 4 individual coils and no dizzy drive outlet on the exhaust cam?
No changes about the starter motor position or change of aux belt routing?
Cos if it's the same bar a few things I may go for the 1350 over the 1275
Well it's the engine+gearbox so the plan is to just drop it in :) cheers for your information frank your well helpful. I should make a build tread on here tbh about my Micra mini!
Lawrence
Well that's not a problem as I have plenty of dead space in that part of the engine bay. I'll make a new thread sometime in the new year then.
Lawrence
