cat replacement
P
Pyro
Hey guys and girls,
I replaced my back box a while back and now its time to replace the cat. I know sebring makes one and Janspeed too if i got it right. But will you pass the MOT with one installed? The engine is pretty much standard and wont get too drasticly modded so...
* I should have mentioned, I have a 1998 1.3, so with 2 cats...
if you keep your origional manifold then it should pass mot's iirc :) the post 98 models only came with 1 cat (in the manifold) as nissan did away with the second.
try doing a search this has prob been asked before :)
:devil: I have a K11 1L Micra W reg it passed mot test and emsions test with no problems!
i had only second cat on, don't use decat pipe pain taking it off all the time for car tests!
i have the follow mobs on car:
CAR MODIFICATION LIST
ENGINE:
• INDUCTION KIT – PIPERCROSS
• EXHAUST BOX - JANSPEED
• MANIFOLD - JANSPEED
• POWER BOOST VALVE - FSE
• FUEL PUMP - FSE IN -TANK
• STRUT BRACE - OMP
• OIL FILLER CAP - PRO
BRAKES:
• BRAKE DISCS - BLACK DIAMOND
• BRAKE PADS - BLACK DIAMOND
WHEELS & SUSPENSION:
• 15inch ALLOY WHEELS
• 35mm DROP SPRING KIT - PI
