right i havent used the car since tuesday so today i went and washed the car then went to start it wont start its turning over trying to but wont any ideas
Maybe the electrics or something got wet when you were washing it, try leaving the bonnet up for a bit to get some air in to it and dry out a bit. See if you can start it up then.
happens to mine regular take petrol cap off and let tank vent try starting it then if still no joy put petrol in as it may be to low sounds daft i know but it works every time for me.....
Right i fixed it final started after pushing the acce pedal right down but there seems to be a noise coming from near the belts in the engine bay sqecking noise pretty loud i can hear it in the car
Whats happened, the cars probably flooded itself, As for the squeeking its more than likely gonna be your fan belt or PAS belt thats slack, and the water from washing your car is allowing it to slip - simple enough to tension back up again mate.
