Car wires all messd up head unit memory not avaliable
I had my car broken into and the wires were cut an messed up
When the new ISO block is wired in and the cd player is fitted we had to join 3 wires and 3 wires to get it working.
The Memoiry on the head unit dont work and the memory on the speedo dont work
The speedo dusnt work however when i turn the head unit on the speedo works
My wiring is apparently messed up and i need help big style
Im located near middlesbrough in the north easy and would wonder if anyone can help me
Dazza
will this solve the two problems With the speedo and the Memory
I cannot understand the way the speedo is wired in
I got some one else to do it and they cannot understand why
Any ideas why the speedo only works once the the cdplayer has been swithched on
the speedo, cd player and other accessories are all on the same circuit, if one is wrong they all are. Swapping the ignition and battery connections to correct them should fix all the faults.
