okay so my car has a sunroof, and i am sure the blockage pipes are blocked.
the car is parked on a tilt, so all water goes to passnger side basically, then thats when i got the leak, pain in the neck when it gets in the carpet.
so i manged to stick a screw driver up the sill hole, and unblock, make it drain.
so water drains from that hole, and is fine with normal rain, but come with heave rain, or constant normal rain, it does seems to drain aways fast enoth and of course over flows into passnger side.
now i heard there is some more drainageholes behind the wheelarch cover, but the one of the screw is nacked,and i cant unscrew it with a trye there. also of the arch bottom side, there is rust, so the water seems to causing rust.
so in the mean time stock a car top cover on it.
so any ideas, worth removing the wheel or get some else to do it.
or maybe drill holes.
