1.3 cams in a CG10 make for a very good modification. With regard to injectors and the throttlebody, you'll be fine with both for the usual bolt on modifications. There's plenty of headroom in the fuelling system on a 1.0 engine. CG13's are a different matter however.
With regard to the GA16 injectors and a bit off topic but....
I would like to clarify on the capabilities of the GA16 injectors. GA16 injectors are just and I mean just good for 140hp and the duties are far from optimal, circa 95% duty, which is far from ideal.
Not many here push that far power wise but for 140bhp a more sensible choice of injectors, (based on 80% max duty), would be 230cc/min. 140hp+ I would recommend 270cc/min, which would see ~160hp comfortably.
