CMF_Stevo11
» CMF MemberHi,
My Micra (998cc 1998) died recently while coasting to a stop at lights, no bang, no noise, no drama. I had a look at it today, it turns over on the starter, (haven't managed to check spark or fuel yet), one thing I did notice was that if I poke a finger through the oil filler hole I can just loop around the timing chain and pull it slightly upwards... I'd have thought a chain snapping would have pulled it off the cam sprocket (?) and mashed valves etc with some sort of clatter... but there is no such indication... is this just due to the tensioners not taking up slack? If so.. where should I look next? Is there a common issue I should look into first before checking spark/fuel?
Any ideas?
Thanks in advance!
Steve
Any ideas?
Thanks in advance!
Steve
