OK..
whats the best way to remove the nut that holds the ball (of the tie rod outer ball joint) onto the hub/knuckle....when the nut is so corroded to the threads, that turning teh nut just seems to spin teh ball (inside the joint)???
so I need to separate teh joint and then do a crazy clamp arrangement on the balll....
...or can i do some kind of 'twist' technique on te4h socket end to hold the ball still while I remove the nut?
The first side came off no problem but the seccond side is being a beeeatch!
dont mind replacing th ejoint ofcourse......just dont know how to get the ball off of the hub/knuckle
HELP!!!
cheers
HELP!!!
cheers
