Hello, I did take pictures, but I moved house not long after, do you think I can find the sd card I used?... nope. But I can try and answer some questions if you like
Brilliant thanks ill go to scrappy tomorrow I know its off topic but with you having same year car does your outside temperature and trip computer in your speedo work as mine isn't showing up and apparently we cannot fit the trip computer above the radio as its a different iso in the facelift modelsMines the same age 2006 on a 55 plate, I think I'm right in saying if you have clear front indicaters, it's a facelift which is what I have. Yeah I had the foam stuff, it just covers where the speaker would be. I replaced the door looms for ones that had the speaker wires. Which connect to a connecter in the b pillar it's behind the the big plastic cover on the bottom half of the pillar which pulls off. Then there's a small plastic cover about in the middle of the pillar, which hides the connection for the rear doors. This is where the rear speaker cables stop, you could cut into it but I have no idea which wire is which, so I just got the door looms for £10 each with the speakers included from a scrappy
All mine has is a clock and a trip, Iam guessing the higher specs have outside temp. When I changed the stereo I didn't see any extra cables in that area so I don't know about adding the extra screen in the middle. You can get universal outside temp kits on eBay, no idea if there any good mind
What have you done/ plan to do?
I just swapped them 1 for 1, have fun catching your hands on the inside of the doors
