Okay, Problem with the brakes on mine, when driving around town/normal roads after a while the brake pedal goes rock solid, as in gently put your foot on the brake and almost go through the windscreen solid, but if you turn the car off and leave it for a minuet or so its fine till it does it again, any thoughts on this would be greatly appreciated, I recon its the master cylinder, I have been wrong in the past though
