sonic Jan 21, 2007 #1 It's been covered a thousand times before I know, but which Almera brake calipers and discs fit the K11 with the washer spacers, I've tried a search but it left me a bit confused as to whats what.
T Type-R Ex. Club Member Jan 21, 2007 #2 almera or sunny n14 calipers fit k11, whether it be 1.6 or Gti-r! and yes you need some washers in between the carrier bolts and hub to have some clearance.
Z Zephyr Ex. Club Member Jan 21, 2007 #3 i do have the guide which knieval made yrs ago can pass it on 2 u if u want
OP OP sonic Jan 21, 2007 #4 Zephyr said: i do have the guide which knieval made yrs ago can pass it on 2 u if u want Click to expand... yes please, that would be a help.
Z Zephyr Ex. Club Member Jan 21, 2007 #5 [email protected] add me on msn if u use it or email me then i send u it
OP OP sonic Jan 21, 2007 #6 Type-R said: almera or sunny n14 calipers fit k11, whether it be 1.6 or Gti-r! and yes you need some washers in between the carrier bolts and hub to have some clearance. Click to expand... would the N15 Almera fit ?
Swiper Ex. Club Member Club Member Jan 22, 2007 #7 sonic said: would the N15 Almera fit ? Click to expand... yes, the 1.4 and 1.6 are the same i think, and the gti are the same as a sunny/pulsar gti-r
A Alienfish360 Awesome Dawson Jan 23, 2007 #13 I was always led to believe it was 1mm, but it seems as though 2mm is ok too
