https://micra.org.uk/cmf/message/5749
With the pulsar brakes:
N14 Q 1.6 > 18mm Disc - 250mm diameter > will fit inside 14"
N14 SSS 2.0 > 20mm Disc - 252mm diameter > will fit inside 14"
and
N14 GTIR 2.0 & N15 SSS 2.0 > 26mm disc - 257mm diameter > bigger calipers, so will fit inside 15"
http://www.dba.com.au/nissan_2005.pdf < thats a good reference
Bendix Brake Pads for Pulsar's:
DB1216 - N14 1.6L
DB1148 - N14 2.0L
DB1302 - N15 1.6L
DB1281 - N15 2.0L
second time round i go the N15 1.6, as SSS said their newer > otherwise N14 1.6. Pads for my N14 2.0L brakes are hard to come by due to the performance lines being discontinued by manufactures. And same with the disc's, plenty of 18mm discs avail but i haven't found any other 20mm discs but the DBA's yet.
some more info to confuse. I doubt the accuracy of these weights > think their avg shipping weights, i got them off
www.discpads.com.au , but what it shows the considerable weight difference of the monster brakes which cisco mentioned, plus the bigger calipers.
Disc Rotor Weights:
DBA420 4kg - K11 1.3L
DBA628 5kg - N14 1.6L
DBA900 5kg - N14 2.0L
DBA899 4kg - N15 1.6L
DBA901 7kg - N15 2.0L
Alex
