brake queries
djlee_dj
what size of piping .... and also screw/nut/end's are used for 1993 k11 ?
also what size spanner will i need to do a full set of brake pipes on the car ?
i can't remember the size of the pipes etc, but the spanner you need is 11mm (try to get a propper flared nut brake pipe spanner, or you'll round off the nuts), possibly 8mm for the bleed nipples.
