CMF_1300cc
» CMF Memberother nissan brake booster master cylinder will direct bolt to micra? , need to replace mine...
1300cc WROTE:
"other nissan brake booster master cylinder will direct bolt to micra? , need to replace mine...
Mimz WROTE:
"1300cc WROTE:
"other nissan brake booster master cylinder will direct bolt to micra? , need to replace mine..."</div>
Why? Normal one is fine. If you increase ur brake calipers to say GTir one, just change ur brake master cylinder. Why the booster?
1300cc WROTE:
I thot i hav to change the whole assembly?...,n im not tring to increase the braking just wondering if n14 or n15 will b cmpatible<BR>V
asdame WROTE:
"Try cleaning the iav and adjusting the idle speed screw to spec first
