I know there are already a couple of threads on this but I'm still a bit confused, I'm just about to 're-route my fuel lines to the inside of my 1998 micra k11 1.0l which I'm preparing for stage rally and upgrade to stainless braided pipes.
My question is what size pipe are people using? 6 or 7mm?
When I look at the original pipes on my car it appears to use both sizes by starting in 7mm rubber pipe from the pump and then 6mm solid pipes under the car and back to 7mm rubber in the engine bay.
So should which should I use?
Any advice please
Any advice please
