evenin peeps just a quick question to throw out there. The crank pulleys on the 1 litre and the 1300 are different in weight , check
Question is are the timing marks the same or different ? I.e. If you used for instance a 1 litre pulley on a 1300 and set it at tdc would it be a true setting ???
Many thanks as usual
