Hi read lots of threads on K12 boot locks... but they all seem to describe fastener problems not central lock problems.
Here's my tests (writing it down for sanity)
1. Boot switch (common fault) - checked and it works - tick! - shame, wish it was this one lol
2. Boot Fastening Mechanism - took out and tested with a 9V battery... - yup the motor servo works and unlocks correctly - tick
3. Tested the wiring. The power to the switch is live & when the switch is pressed it sends the power to lock the lock just doesn't respond (but I know it (should) work cos I tested it with a battery!!)
Just once when I refitted the lock it worked with the boot button...
Could it be a central locking issue. Does the central locking deactivate the servo that flips the clasp open?
There are 4 wires going into the Boot clasp mechanism. 2 operate the servo to unclasp the mechanism. I assume the other 2 are the 'lock' i.e. disables the servo from operating the clasp...
I can't find any threads or videos describing the electronic central locking mechanism. Does the electric locking disable the clasp servo? is that the issue?
Thanks in advance for any advice
