cisco
» CMF MemberLast week, I had the gearbox split-open, inspected and re-assembled to make sure everything was sweet before installation.
The results were very good. Its in virtually brand new condition inside. The 5th gear fork has some very minor wear marks on it, which basically shows that it is used and now brand new. The front retainer is also the same. But both items are very close to new condition and definately not in need of replacement. Apart from that, all gears, syncros and bearings are in perfect condition.
The driveshafts have been serviced with new grease and boots now also.
Errol from Datrats has been helping me source a clutch and I'm just awaiting its arrival. Its going to be a heavy duty exedy brand 190mm GA16DE pulsar clutch. Bolts up to the micra's flywheel perfectly.
So everything is on track, so hopefully blue monster will be back in action by next weekend.
