bleeding clutch micra k12 2004 plate
any idea how to bleed the clutch on k12 micra the bleed nipple is fixed ie cannot be opened or closed the haynes manual says lift the clip upwards but do not remove and pull the pipe out 5mm I assume
this is the correct position to allow fluid to come out of the bleed nipple??? then I take it once the pipe is pushed all the way back in fluid can not pass the nipple is this the correct procedure for bleeding???
yes, depress the clip and pull out pipe approx 5mm, allowing fluid to flow keep fluid topped up it'll drain through with gravity. when bubbles stop push in pipe till it clicks and try clutch, repeat this process till all bubbles are gone and you just get fluid flowing out of nipple. don't pump out fluid with clutch and stuff like that, it works, just makes huge mess lol
