That had crossed me mind low rider if i can incorporate the stock tb to open the butterfly value in sync with the carbs to see if the ecu would adjust the ignition accordingly, it wouldnt be perfect but may help.
As iv got a 5.1 crown wheel fitted i find im up into 5th quite quickly. (1st is nearly obselete!) I still have the stock rev limmit fitted (6500?) so i may raise that especialy as it does not seem to come on cam until 4k.... there does seem to be a lul in power from 3k to 4k @ around 70mph more than anywere else in the rev range so a tweak here on the ignition could prove useful!
If i can get my hands on a consult cable i will deffinatly post up the results!
(frank) your ecu will only be getting rpm signals for the spark map eh (and no load input without maf and tps )
Sorry to resuscitate...
I've been back reading on some of these. How can you all run without a MAF? On my throttle body setup on my dead micra my car wouldnt even start with the MAF unplugged, or plugged but not in the inlet stream!! - WHY!???? Beside the obvious, i guess what i'm asking is how come some people can manage. Am i an imbecile?
