Any personal recommendations? Saw a can of interior black paint for cars in poundland, got a can for a laugh... The quality of the paint is a laugh. I now have a patchy/drippy dashboard that needs redoingany plastic primer then spray paint and clear coat
Thanks for the advice, appreciatedits only like 7 or 8 quid for a big can if i remember correctly, any DIY shop sells the stuff for about a tenner a can
yea just sand everything down and start again but take your time and build up the layers slowly, good tip is keep your hand moving so you dont spray too much in one place
again halfords lacquer does the job
also sanding and primer first is a good idea because it gives better surface for the paint to stick too, if you are spraying straight onto the plastic without sanding or priming first it wont work too well
Haha yeah I could imagine. Thanks for the heads up a shiny effect is what I was looking for yeah. It's shiny the bits I've done, but drippy too. One tin of paint only covered the fuse cover, cover under your cig lighter/ashtray in front of gear stick and also the cover around my speedometer. Didn't cover much but then again it was only £1Shiny speedo cover reflects light on the windscreen in my case. Wasnt the best idea haha
