best + - connections
what is the best place to wire someting into???
I am putting a 4way faglighter thing in the car but as i dont have an original fag lighter in it i am going to have to connect it somewhere. I have it all wired and ready to go with a on/off switch in line
Should i just run it straight through to the battery or is there somewhere inside that i could connect it to??
How many amps will you be pulling through the lighter adapter? If you do run it to the battery, make sure you include an inline fuse :)
All done and working fine :)
Ran it direct to the battery with an in line fuse. Also put a switch in aswell so it can be turned on/off.
Fitted in the space in the center consol just infront of the gearstick.
