Bench Bleeding...
Need some quick advice,
I spent much longer than expected yesterday swapping the brakes, suspension, and cv boot. (vented disks didn't fit in the calipers and the trackrod end split pin needed drilling out).
What this meant is that the brake line was left open for several hours, and drained the system. My friend got in the car at some point and also pumped the brakes (luckily when the caliper was back on).
Any suggestions as to bleeding the master cylinder? Is it accomplish-able without removing it from the car?
M.
Wahey! Was worried as the last car I worked on was a nightmare to bleed the master cylinder. Will bleed today, just need to find my bleed kit :p
