timmchugh1
I've been to the scrappys this morning as I am after doing a 1.3 conversion, i just have a couple of questions. And yes i have used the search but i just want to be clear on everything before i spend loads of doh.
The engine I have found is a 1.3 (cg13 near the bellhousing on the front of the engine) the fly wheel looks to be a auto flywheel! (either that or its super light lol)
Will a 1.0 flywheel just bolt straight on?
Also I can save £30 if i dont get the throttle body. Are the 1.0 and 1.3 throttle bodies different?
The car I am going to put it in is a 2000 1.0 profile so it has NATS, now I am planning on useing the same ECU so i can keep NATS and I dont have to mess about with the wiring loom to fit a non NATS ECU. This should work?
1.0 gearbox is it a direct fit onto the engine I have found?
Are there any other complications I may come across?
Erm I think thats it
Any comments would be a great help!!
