Recently purchased a Bee*R Rev limiter and Im needing a bit of help with wiring it in, @Scott.c (member on here) done a wiring diagram for a distributor type micra but I've got a post 2000 coilpack engine, so the ecu is completely different.
There's a choice of 4 wires; a red(12v supply) black (ground) a green one that goes to the crank angle sensor at 120' or 180' and a yellow one that goes to the crank angle sensor at 1'
I've looked on that Dropbox thing for the micra pdf files and found that pin 16 and 43 are the crank sensor
If anyone could shed any light on this I'd be really greatful because I'm useless wi electrics
