bearings
CMF_Pierce
AB-NRML WROTE:
"I went to Nissan today to price bearings. Big ends and mains will cost me $1000+ at trade prices.
Just thought I'd let people know.
Okay...
That's ridiculous!
I need a full set and that is a shiiiet load of money. Pretty sure that Danvillan got back to me on some thread that it would cost around $600, though could be wrong :/
Anybody else had the big ends and mains quoted?
EDIT: quick question. If my original bearings look fine and the crank didn't have any scratches on it (no. 1 had a very light scratch, buffed out now); can I use them again reliably?
CMF_frank2
Pierce WROTE:
best to check with plastigauge really pierce (i use baking foil tbh)
and GA16 b/e bearings are the same size iirc
and polly used MA mains shells
CMF_AB-NRML
Big ends were something crazy like $150+ they come as the pair.
Mains were $15 or 18 a half and are graded by size (no surprise there). My Nissan man tells me that you can have 2 or even 3 sizes along the crank.. from the factory. So the engine needs to be opened to find out the required sizes.
After he told me the cost of one I stopped paying full attention, I was in shock I think. For interest I might go back and get the exact prices soon.
CMF_Pierce
This is off nissan4u.com
It shows how to choose the right bearings and your guy is right, there are sizes STD 0 through 6.
I'm having trouble viewing my punches/markings after the engine was cleaned and machined plus it's late and I'm tired. I'll have a better look tomorrow and once I figure it out I'll post about it here.
CMF_Pierce
FYI,
If you haven't pulled apart your block yet, as soon as you remove your pistons and rods, make sure you put your bearings right back on them, and keep them in order, then draw a diagram labeling which ones go where, and what size they are. They all have STD # (1-6) pressed into them. They may be dirty and hard to read though ;)
CMF_frank2
those numbers on the block are pretty irrelevant on a 20yr old engine tbh, there is only .3 thou" difference in scale
plastigauge will assess the wear/clearance, but it wont acount for the inevitable ovality tho.
i always fit little squares of foil (1 thou" thickness) onto the journals and assemble the parts, then torque the bolts down to check the clearance
